× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
No power
Winery13
Follower
No power
MR1100-100NA
Been working fine for months. Today randomly there is absolutely no power to the unit and it will not turn on at all with either battery installed or battery out and plugged directly into the wall power with the supplied correct voltage plug and cable. Still under hardware warranty but website does not give any option for help except community or FAQ. It’s registered and a support ticket is created. How do I return the unit as it seems the hardware has failed. Thanks.
Message 1 of 3
Guru
Re: No power
Have you tried a different power supply and cable?
Message 2 of 3
Retired_Member
Not applicable
Re: No power
change the power supply cable.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 474 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
