- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi 4G LTE Advanced Modem + Tri-Band Mesh WiFi - AC2200 LTE Mesh Router (LBR20)
- Mark as New
- Bookmark
- Subscribe
- Permalink
My question is does the Orbi 4G LTE Advanced Modem + Tri-Band Mesh WiFi - AC2200 LTE Mesh Router (LBR20) Broadband Modem/WiFi Router work equally well with a Voice SIM or Data SIM only or both???
T Mobile tells me that most major cellular carriers provide data SIMS that are limited to 50 GB per billing period typically used in a hot spot. This approach, while useful as a backup, limits the AC220 to 50 GB and makes it a challenge to replace cable services or other ISPs on a fill time basis with this 4G LTE Tri Mesh Modem if you stream quite a bit. The carriers can also proivide a TRULY unlimited data VOICE and DATA SIM making the AC2200 more useful as a full time ISP. If you casn use a Voice and Data SIM with unlimited vice and data, you can truly take advantage of uinlimited data and use the AC 2200 as a fulltime ISP replacement. The indication was that some celluar modems are only compatible with a Data SIMs it you install a voice SIM, it won't recognize the SIM and will fail to operate.
Please acdvise....
