× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Problem with LB1120
Miguelchr
Problem with LB1120
Hi i am having the same problems as  in this post:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Problem-with-LB1120/td-p/1561713
But in the post there is no fix to the problem
Thanks in advance
Model: LB1120|4G LTE Modem
Message 1 of 4
ArodiD
NETGEAR Expert
Re: Problem with LB1120
Hi @Miguelchr ,
Can you please try holding the factory reset button longer than 5 seconds?  Stop pressing when you see a change in the LED's.
Arodi
Community Team
Message 2 of 4
Miguelchr
Hi Arodi i did a few tries holding the reset button for around 1 minute but still the modem does not change his led status red/on/off/on/off
Thanks for the reply
Message 3 of 4
Blanca_O
NETGEAR Moderator
Hi @Miguelchr
May we please know the exact model of your device? Where did you purchase it? What happen prior the issue?
Blanca
Community Team
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1157 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
