× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Unite pro
Slogait
Follower
Unite pro
I have a unite pro that was working fine. Then I get 2alerts saying broadband disconneccted and insert a sim card. It had a sim card in it. I took it out and put it back, nope. Reset the device, no luck. Tried another sim card, nada the alerts are still there and mifi will not connect to internet.
Any ideas?
Model: AirCard 781S (AT&T)|Unite Pro
Message 1 of 2
Blanca_O
NETGEAR Moderator
Re: Unite pro
Hi @Slogait
Welcome to NETGEAR Community!
Did you purchase the device from AT&T? Since you already reset the device and it did not resolve the issue, kindly contact AT&T to check the SIM card and/or the device.
Blanca
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 772 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
