× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
netgear 790s strange and big problems
mariano86
Follower
My netgear 790s this morning presented some big problems.
Soft touch buttons don't work anymore, and name of connection and password dissapeared from main screen
I've tried a factory reset, but without results
What you suggest to do?
Model: AirCard 790S|BigPond/Telstra Wi-Fi 4G Advanced II
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: netgear 790s strange and big problems
Hello mariano86
I would contact your provider that you purchased the device from check if it is still under warranty.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2799 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
