- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
won't stay on when using as hotspot
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: won't stay on when using as hotspot
This is a very strange problem, as this surely "should not happen".
Since you write that you already exchanged your M1 and the second one acts just the same, I suppose there might be something unique to your environment that causes this. Are you operating your M1 in a very hot and/or humid environment? (If yes, a possible thermal shutdown comes to mind.) Or are you using the same power supply or USB cable which happens to be defective? Are you using the Ethernet port? (If yes, does it happen without the Ethernet cable being connected, too?)
As you see, more information would be needed in order to help you (and also post the model and firmware version numbers as already requested by @Blanca_O!).
