akomaha04's avatar
akomaha04
Follower
Aug 09, 2018
Disney Circle Passcode Reset
Is there a way to reset the circle passcode?  I'm talking about the 4 digit passcode that's required when you initially install the app.  My son installed the app on his phone and grabbed the passcode from our phone and now can control Circle as well.  The passcode is under Manage, but there's no option to reset it.
  • Hi akomaha04,
    Please try the following steps:
    1. Uninstall the Circle App on your kid’s phone
    2. Reinstall Circle on your device
    3. Select the option "I’m the only Circle Admin" and a new passcode should be sent on your mobile via SMS
    4. Change the security on your phone and setup pin lock to ensure that your kid won’t acquire the code again
    This link as well as this link may help.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi akomaha04,
    Welcome to the community!
    Let me check on this.
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi akomaha04,
      Dexter
      Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi akomaha04,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
      • Slick22's avatar
        Slick22
        Initiate
        I have the same problem. But I never receive a text with a new passcode. I need to reset my phone number I guess?
