- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Parental controls breaking
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
For whatever reason, my Orbi app stops updating the profile history from within parental controls. As far as I can tell, the Orbi is applying the restrictions from the profile, however, no usage or history data is available. This has happened one other time, which after a call to support, resulted in a factory reset. The only change I made to the router was the addition of some static IP's, which required a reboot. Constantly factory resetting isn't really a great option! With this last issue, I:
Rebooted the router again
Unistalled and re-installed the Orbi app
Also worth noting, is that on the Orbi main screen, the image of the Orbi doesn't show, and just a black shadow displays (image attached)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Parental controls breaking
Hi ianmclein,
Are you still experiencing this?
May we please know the model number and firmware version of your Orbi System?
Kindly check as well if you have the latest Orbi App installed.
Blanca
Community Team
