- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8000 with Circle
- Mark as New
- Bookmark
- Subscribe
- Permalink
R8000 with Circle
I use Circle Home app for parental controls with my router R8000. The internet speed is drastically reduced when I use Circle. My internet speed without circle is 300+ MBPS. but with cirle it goes down to less than 100 MBPS. Any workarround or updates from Disney/Netgear to solve this issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000 with Circle
Hi @Circleuser, welcome to the community! We recommend updating to the latest firmware found here and do a factory reset as described here. Also, does the issue persist on all your devices (wired and wireless)? Do you have any QoS features enabled as well?
Dexter
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. Yes, the firmware is the latest. The QOS is not enabled. But if I disable Circle and restart the router I get 300 + MBPS speed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the slow down is there on both WiFi and Ethernet connections. Max speed I experienced with circle enabled is around 100 mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Factory reset is done as well. No change in speed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Disney Circle by default caping the speed at 100 mbps. This is their disclaimer, due to the wirless protocol they use. It's bit strange why they are not finding a workaround for this yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, there is no solution to this yet. Please work with disney circle and remove the speed caping at 100 mbps.
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
