Orbi WiFi 7 RBE973
Reply
Xbox Call of Duty Black Ops 4 INCOMPATIBLE with Circle
john442
Tutor
The Circle Parental Controls is COMPLETELY INCOMPATBILE with the XBox Call of Duty Black Ops 4 game.
You have to set the filter to NONE or unmanaged device for this game to work.  Even at Adult with everything allowed it WILL NOT WORK.
The problem here is I can't limit time for my teens because (some dumb programmer) decided that None and time limits don't work.
Is there a fix for this?
Message 1 of 8
john442
Tutor
Re: Xbox Call of Duty Black Ops 4 INCOMPATIBLE with Circle
No one else has this problem???
Message 2 of 8
DexterJB
NETGEAR Moderator
Hi @john442,
Welcome to the community!
I have sent you a message. Please check your inbox.
Dexter
Community Team
Message 3 of 8
john442
Tutor
Reply sent
Message 4 of 8
TheAvo
Initiate
I am also having this problem.
Blackops 4 will not work when circle is enabled.  No filtering or anything, just won't work.
Model: R7000P | AC2300 Nighthawk Smart WiFi Router with MU-MIMO
Message 5 of 8
Mflint
Are you able to post the fix for this on the public forum? I see you sent a message to another user. I am having the same problem with Call of Duty Black Ops 4 being blocked by Circle. Please either post the fix to the forum or send me a message. Thanks.
Message 6 of 8
john442
Tutor
Sadly no.  I can't post it because there isn't a fix yet.  I am going back and forth with their support, but they haven't even proposed anything yet.   (To NetGear support:  Please update your website the case page doesn't work with Firefox or Edge browsers--I had to use Chrome to be able to respond)
Message 7 of 8
john442
Tutor
Update, so far they proposed a workaround:
Create a separate profile and configure off time.  However, that's not viable as it still doesn't track time spent, just lets me limit it but its too inflexible.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3309 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
