mvrana's avatar
mvrana
Tutor
Aug 12, 2017
Mono 5.0 works (+ Jackett install)
I'm not sure if it's related to the 6.8.0 firmware update, but Mono 5.0 now installs very nicely overtop older versions. I just followed the directions for the Debian 8 install here:
http://www.mono-project.com/download/#download-lin-debian
And it installed no problem.
Sonarr and Radarr continue to work perfectly.
I was able to install Jackett  (https://www.htpcguides.com/install-jackett-debian-linux-custom-torrents-sonarr/)
In fact, the whole reason I installed Mono 5.0 is because Jackett prefers newer versions than the 4.0.? (sorry, can't remember exact version) that was available to ReadyNAS previously.
  • Thanks for this - I updated my ReadyNAS and Sonarr stopped working. Was able to get it going again by upgrading Mono.
    Quick note: you will have to add the Debian 8 keys before the upgrade will work even though you might already have had Mono installed successfully previously.
ProSupport for Business
