Orbi WiFi 7 RBE973
Reply
ADSL LED OFF
jackfree5
Follower
ADSL LED OFF
The ADLS led is switched off and the World Icon LEd as well. The other led, wi-fi and usb are ok. I have connected another netgear modem router and everything is ok, it means that the Internet Service is ok. Yesterday, the weather was storming. I think that a thunderbolt may has been the problem. Is my D6300 definitevely dead? Can I do something to fix this problem?
Many thanks
Model: D6300|Dual Band 11ac ADSL Modem Router
Message 1 of 2
Accepted Solutions
Re: ADSL LED OFF
This would not be the first bit of kit killed by lightning.
Before you recycle it, have you tried to reset it to factory settings?
If you can use the web interface, you could even try to flash the firmware to the latest version. Indeed, any version.
If none of that works, then Thor may have done his thing.
Message 2 of 2
All Replies
Re: ADSL LED OFF
Message 2 of 2
Discussion stats
  • 1 reply
  • 3390 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
