- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't access some sites after firmware upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since updating to firmware v1.0.0.66 (link) I've noticed that traffic is seriously impeded.
Some sites are unreachable entirely; things like SBS On Demand and ABC Iview - whilst others load, but certain content does not; like the TVshow/movie tiles on primevideo.com or the ad pictures on Ebay.com.au.
Everyting else in my networking environment has stayed the same - just the firmware is different. I've tested this via different PCs (both hardwired and wireless); from gaming consoles - but the result is the same.
I'll be doing more treoubleshooting over the next day or so; including swapping out a different modem, doing a downgrade and replacing patch leads (from the modem to the router) to test different things - but just wanted to see if anyone else has experienced something similar?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Plemans,
I've not tried that , but it's a good suggestion. I've update the FW a few times on this device and have only done a factory reset once or twice (when the release notes recommend it).
Have don'e some other teoubleshooting and it seems to have been a faulty patch lead (between the modem and the router). If anyone else has had the strange experience I note, be sure to start with the basics!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't access some sites after firmware upgrade
Have you tried writing down your ISP settings, factory resetting it and then reinstalling it?
Anytime there's an issue after updating firmware, a reasonable first step is factory reset and manually reinstall it in case an old setting is causing the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Plemans,
