Orbi WiFi 7 RBE973
Reply
Cant create network folders
InsaneGenius
Follower
Hi everyone can someone help me out with creating network folders with a usb storage attached to the modem router. I am trying to have 2 folders one for dlna no password and one for docs with admin access.
The dlna folder works because I enabled media server and the modem created a .readydlna folder but when i try to make my second folder with admin access I click edit>browse>selectedfolder then add a share name I keep getting "folder does not exsist" problem but the folder is there on the drive I created the folders using my pc then inserted the device into the modem. What am I doing wrong?D6200_1.jpgD6200_2.jpgD6200_3.jpg
Model: D6200|Dual Band 11ac ADSL Modem Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Cant create network folders
Hello InsaneGenius
Have you found a solution to this yet if not let me know I will try to replicate the issue.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2642 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
