Orbi WiFi 7 RBE973
Reply
D6220 firmware update fails
long_tall
I tried to upgrade from firmware version 1.0.0.22 to 1.0.0.52_1.0.52
it contacted the netgear server, but after a few minutes gave a
Failure Unknown error:-1
Can anyone sugest what to do next?
thanks
Model: D6200v2|AC1200 WiFi DSL Modem Router
Message 1 of 3
Accepted Solutions
antinode
Guru
Re: D6220 firmware update fails
> D6220
   What's true?
> I tried [...]
   How, exactly?
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Downloads.  (For older versions, under Firmware and
Software Downloads, look for "View Previous Versions".)  Find the
kit(s).  Download the kit(s) you want.  Read the "Release Notes" file
for instructions.
Message 2 of 3
All Replies
antinode
Guru
> D6220
   What's true?
> I tried [...]
   How, exactly?
for instructions.
Message 2 of 3
long_tall
thanks - that worked fine 🙂
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4076 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
