Orbi WiFi 7 RBE973
Reply
D6400 wireless schedule not working
JealousCleric
Follower
Hello
I had a schedule for the 2.4ghz radio on my d6400 but its stopped working.
Randomly a month and a half/2 months ago the 2.4ghz radio turned off and it seems since then the set schedule does not work. As you'll see in the screen clip below the options to enable, edit or add schedules are completely greyed out.
Firmware Version
V1.0.0.94_1.0.94
Please help
Message 1 of 2
Re: D6400 wireless schedule not working
@JealousCleric wrote:
Firmware Version
V1.0.0.94_1.0.94
Your first move should be to get the latest firmware for your D6400.
There have been five newer releases since yours.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Is your device in modem/router mode?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 572 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
