- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7000 Freeze / Lock up
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have tried the latest firmware and factory resets but the problem still persists.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7000 Freeze / Lock up
Hello arb44
You will have to contact support if there is a hardware issue with the unit.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello
I've found I have no problems with stability if i disable the wifi entirely. There is definitely a fault here.
It seems although I have a warranty on the device, i need to pay to initiate an return or to get someone to troubleshoot this. Is that right? I've never seen a vendor insist on that before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same problem. Posted a new discussion, so maybe I can get some help with it. Can't believe the amazing wifi router will only work with wifi disabled. What crap is that? Hope Netgear get's it fixed very quickly. Would hate to think the router is that expensive and total trash.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello NbyronGriddin
Have you tried to isolate the issue by removing all the wifi devices on the network and connect one at a time to see maybe if a device on the network is causing the issue?
DarrenM
