Orbi WiFi 7 RBE973
Reply
D7000 Updates
County
D7000 Updates
Smiley Frustrated
Does anyone know why the D7000 is not seeing updates when you check via the genie app?
I have just done a manual update from 1.0.0.34 to 1.0.0.38. I do a weekly update check via the genie but it never finds any updates, it is only when I do a manual search on the web site or when the modem/router locks up.
Message 1 of 2
clithes
Prodigy
Re: D7000 Updates
Not sure why the Genie doesn't show the new firmware.  If you log into the D7000 GUI it tells you straight away when a new firmware is available.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2273 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
