- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7000 VPN broken after 1.0.1.74 firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
just updated firmware to 1.0.1.74 on my D7000, and lost remote access via the built in VPN, which was working just fine previously. Tried all the usual options (clearing openVPN settings etc), but no joy. Is reverting to the previous firmware the best option here or is there a fix in progress?
thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7000 VPN broken after 1.0.1.74 firmware
With the crappy firmware Netgear is putting out I would suggest you revert to the version that was working for you. NG for maybe a year now, has been going through building and releasing really buggy firmware with the same issues from release to release. Seems they farmed the firmware out to third part off shore outfit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
rolled the firmware back, VPN still not working. Can't think why... most annoying. Going to have to try changing the various settings to see if some changes have been made in the config with the various firmware changes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok, after clearing the config on win10 openVPN client, can now connect again using the 1.0.1.70 firmware, so at least that's something. Still need to get my OS X client (tunnelblick) working, but guess that's now just a config issue on the client rather than a router problem now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
unfortunately for me firmware downgrade does not worked. Downgraded to .70 but same issue, my mobile openvpn refuse to connect due to certificate error.
I also played the card of certificate re-creation and re-upload on the router, but that not solved the issue.
There's something else, somewhere.
No more netgear in my life.
