Orbi WiFi 7 RBE973
Reply
D7000 in AP mode and embedded switch
Graphicomp
Dear Community,
I own a D7000 WI-FI modem router and I need to set it up in AP mode.
I'd like to know if the embedded gigabit switch can be used in congiunction to the wifi hot spot.
I mean, can the embedded gigabit ports accept wired connections, in addition to the wireless connection, at the same time? Can the D7000 be used like a wired and wireless access point at the same time?
The user manual reports that when the D7000 is used in AP mode, some features are disabled. Does someone of you know what features will no longer be available?
Thank you so much for helping me.
Kind regards,
Danilo Belardinelli
Message 1 of 5
Accepted Solutions
Retired_Member
Not applicable
Re: D7000 in AP mode and embedded switch
the switch will work along with WIFI any function that requires routing will not work
guest isolation
QOS
Message 2 of 5
All Replies
Retired_Member
Not applicable
guest isolation
QOS
Message 2 of 5
Graphicomp
Great! Thank you!
Danilo
Message 3 of 5
Graphicomp
Excuse me, I've forgotten to post another question...
We found that the embedded switch works along the Wireless access point. Let me make an example: I have a NAS connected to the "main" router, e.g. a R7000, via UTP Cat6 cable (the router may be connected to the WAN) and I have the D7000 set in AP mode in cascade to the R7000.
If I connect a computer to one of the gigabit ports of the D7000 set in AP mode, which is the bandwidth that I can "see" and use? Can I take advantage of the gigabit cabling? Does the embedded switch act as a "normal" external switch?
Thanks in advance.
Kind regards,
Danilo
Message 4 of 5
Retired_Member
Not applicable
Yes
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 5064 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
