Orbi WiFi 7 RBE973
Reply
D7800 Firmware Update to v1.0.1.47 failure
Whisky13
Tutor
Following update I have no internet. Did a reset but no joy, I keep getting the message that there’s no DSL cable connected when going into setup.
Probably very stupid of me, but I had not backed up the settings (getting old and senile) Will the unit have to be returned to Netgear. Or is there a way to solve my problem? Obviously I can still access the internet via my ISP Modem router
Many Thanks.
Model: D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 1 of 9
Accepted Solutions
Re: D7800 Firmware Update to v1.0.1.47 failure
@Whisky13 wrote:
Have now tried two other firmware versions,but still get the message there's no DSL cable connected.
Where do you see that message?
It sounds like you may be trying to set this up using the "wizard".
If so, check the bit in the manual Manually Set Up an ADSL Internet Connection.
There is also a more severe "recoery reset" that you could try:
  • Press reset for 30 seconds
  • Keep pressing reset while removing power
  • Keep pressing reset for another 30 seconds while apply power
Message 7 of 9
All Replies
What do the LEDs on the thing look like? Especially the power LED.
What do you mean by reset? Power cycle? Factory reset?
Message 2 of 9
Whisky13
Tutor
All LEDs are white apart from internet light which is amber. Factory reset.
Is it possible to download the previous firmware from anywhere?
Message 3 of 9
antinode
Guru
   Visit http://netgear.com/support , put in your model number, and look
for Downloads.  (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".)  Find the kit(s).
Download the kit(s) you want.  Read the "Release Notes" file for
instructions.
Message 4 of 9
Whisky13
Tutor
Many thanks.
I guess the unit have to be returned to Netgear
Message 5 of 9
Whisky13
Tutor
I've contacted Netgear support, but get the most rediculous reply imaginable.
Please call us within the next 24 hours with this case number (no number supplied}
Your case will automatically close and won't be valid if we do not recievea call from you in the next 24 hours.
The number is 0344 875 4000. as this is an automated reply system I cannot proceed without the case number
Message 6 of 9
Message 7 of 9
Whisky13
Tutor
michaelkenward
I was just about to parcel the Netgear uo when I recieved your message.
I had tried both easy setup and the manual setup, both failed. I then thought nothing to lose so tried your reset method.  The D7800 is now working.
So a very, very big thankyou.
Regards
Harry
Message 8 of 9
Freaky. Glad it worked.
I'll let you into a secret, don't tell anyone, the recovery reset is something that the Netgear folks ask people to do when beta testing new kit. That's how I found out about it.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2698 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
