- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7800 VPN not connecting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi guys,
I'm having problem with the D7800 VPN. I can connect it when "Clients will use this VPN connection to access" is Auto. But the client public ip won't change if using this mode.
However, when I switched to "All sites on the Internet & Home Network" It won't even connect. The client was able to find the router but it disconnected instantly.
I'm using openVPN on iphone, there's error in the log. - TUN_SETUP_FAILED option_error: option 'route-gateway' must have at least 2 arguments[ERR]
Router firmware: 1.0.1.10
Could anyone help please.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7800 VPN not connecting
Hello papadom
You may want to take a look at this KB
http://kb.netgear.com/app/answers/detail/a_id/29826?cid=wmt_netgear_organic
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI Darren,
that works fine but just when you don't have to let the clients use the home's internet connection, in both modes the route-gateway parameter is not set by openvpn server.
So there might be a configuration issue when the option to tunnel internet is active.
Would be nice to have it fixed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Darren,
None of the options available is working for me:
WRWRWRWRWRWRWWRWWWWTue Dec 20 03:10:11 2016 us=4679 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Tue Dec 20 03:10:11 2016 us=4708 TLS Error: TLS handshake failed Tue Dec 20 03:10:11 2016 us=4797 TCP/UDP: Closing socket Tue Dec 20 03:10:11 2016 us=4819 SIGUSR1[soft,tls-error] received, process restarting Tue Dec 20 03:10:11 2016 us=4828 Restart pause, 2 second(s) Tue Dec 20 03:10:13 2016 us=4940 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Can you please assist me to resolve this issue?
Thanks,
Adham
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Adham
You may want to contact Open Vpn for help on this issue.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI broh I am using Express VPN for my android phone so my suggestion is that use Express VPN for your Android Phone I don't know anything about open VPN
