Orbi WiFi 7 RBE973
Reply
DGN1000 block outgoing packets on mediawiki sites
Mn3m0n1c
Follower
Hello to all,
this is my first thread.
I have a problem with my router DGN1000. The firewall blocks some requests to the websites that make use of the MediaWiki software. Initially I thought it was a problem of my website (I wiki area on the web) but then I noticed that the blocking of packets occurs for sites that use the MediaWiki software (mediawiki itself, wikipedia etc).
The pages of mediawiki sites was loaded but some element of the page is lost. For example the Wikieditor toolbox. I discovered block site by Netgear while analyzing the issue with firebug.
Here's an excerpt of the log:
Sun, 2014-03-23 10:37:49 - TCP Packet - Source:192.168.0.5,55697 Destination:xxx-xxx.58.158.serverdedicati.seflow.it,80 - [BLOCK]
Sun, 2014-03-23 10:38:47 - TCP Packet - Source:192.168.0.5,55737 Destination:xxx-xxx.58.158.serverdedicati.seflow.it,80 - [BLOCK]
Sun, 2014-03-23 10:39:18 - TCP Packet - Source:192.168.0.5,55781 Destination:xxx-xxx.58.158.serverdedicati.seflow.it,80 - [BLOCK]
Sun, 2014-03-23 10:39:21 - TCP Packet - Source:192.168.0.5,55783 Destination:xxx-xxx.58.158.serverdedicati.seflow.it,80 - [BLOCK]
Sun, 2014-03-23 10:39:40 - TCP Packet - Source:192.168.0.5,55791 Destination:xxx-xxx.58.158.serverdedicati.seflow.it,80 - [BLOCK]
Sun, 2014-03-23 10:44:44 - TCP Packet - Source:192.168.0.5,55899 Destination:bits-lb.esams.wikimedia.org,80 - [BLOCK]
Sun, 2014-03-23 10:58:54 - TCP Packet - Source:192.168.0.5,56302 Destination:bits-lb.esams.wikimedia.org,80 - [BLOCK]
Sun, 2014-03-23 10:59:08 - TCP Packet - Source:192.168.0.5,56310 Destination:bits-lb.esams.wikimedia.org,80 - [BLOCK]
Sun, 2014-03-23 11:02:06 - TCP Packet - Source:192.168.0.5,56350 Destination:bits-lb.esams.wikimedia.org,80 - [BLOCK]
Sun, 2014-03-23 11:02:09 - TCP Packet - Source:192.168.0.5,56354 Destination:bits-lb.esams.wikimedia.org,80 - [BLOCK]
A few notes:
    Any ideas?
    Thank you!
Message 1 of 2
wtfsck
Novice
Re: DGN1000 block outgoing packets on mediawiki sites
DGN1000 - V1.1.00.50_ww
Same issue here,
Thu, 2014-12-11 06:48:06 - TCP Packet - Source:192.168.0.2,46901 Destination:bits-lb.ulsfo.wikimedia.org,80 - [BLOCK]
Thu, 2014-12-11 06:41:09 - TCP Packet - Source:192.168.0.2,46611 Destination:bits-lb.ulsfo.wikimedia.org,80 - [BLOCK]
Thu, 2014-12-11 06:40:13 - TCP Packet - Source:192.168.0.2,46584 Destination:bits-lb.ulsfo.wikimedia.org,80 - [BLOCK]
Thu, 2014-12-11 06:39:42 - TCP Packet - Source:192.168.0.2,46571 Destination:bits-lb.ulsfo.wikimedia.org,80 - [BLOCK]
No websites are listed as blocked, keyword blocking is "Never".
Any ideas?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 7664 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
