- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DGN2200v4 frozes
- Mark as New
- Bookmark
- Subscribe
- Permalink
DGN2200v4 frozes
When I switch on the router, it starts up normally: after a while, all the appropriate LEDs are solid green, there is internet connection, my computers and phones can access the network via ethernet cable and WIFI.
After an undetermined period of time (it can be as short as half an hour and as long as a day or two), the router frozes: all LEDs stay solid green, but there is no WIFI broadcasting, no internet, and it is not possible to access the router interface (at routerlogin.net) even from a computer wired to the router via an ethernet cable. The router is frozen and as good as dead. The only way to exit this situation is to switch the router off and on. Then everything is back to normal until the next frozing spell.
I have talked repeatedly with my ISP, and they affirm that there is nothing wrong with the line.
I have tried to factory reset all the settings. I have upgraded to the latest firmware version (V1.0.0.66_1.0.66), but nothing helped.
Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: DGN2200v4 frozes
Hello matial
I would contact Netgear phone support so they can do some troubleshooting with you to determine that it is a Hardware failure if so they can do a RMA on the product if they find it is a faulty device.
http://support.netgear.com/general/contact/default.aspx
DarrenM
