Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
DGND3700 Wireless N 5ghz speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-02-27
04:33 AM
2012-02-27
04:33 AM
Re: DGND3700 Wireless N 5ghz speed
Same behavior here. With fw 1.0.0.12 speed goes up to 160 Mbps at 5 GHz, but with 1.0.0.17 I can get only 54 Mbps.
I've been suggested by the support team to downgrade to 1.0.0.12, but I am not sure what other issues are in that old version :confused:.
Regards.
Regards.
Message 26 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-02-27
10:06 AM
2012-02-27
10:06 AM
Re: GS748Tv4 network saturation
@lgonzalezj, I've gone back to the .12 firmware and have had no "additional" problems. My problem with the 2.4Ghz radio is the same as I described in that thread on this board. The 5Ghz speed and security are as set in the firmware (unlike the .17 firmware). The ADSL connection is rock solid in both the .12 and .17 firmware for me. I think Netgear implemented more problems than they fixed in the .17 firmware!
Message 27 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-18
05:00 PM
2014-01-18
05:00 PM
Hi guys what firmware version do you have I back dated mine to V1.0.0.12_1.0.12
and now both 2.4 & 5g are working on WPA2-PSK (AES)
I hope this helps
Message 28 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-18
05:02 PM
2014-01-18
05:02 PM
Try changing your firmware back to V1.0.0.12_1.0.12
I downloaded and installed it and all working on WPA2-PSK (AES)
hope this helps
hope this helps
Message 29 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-19
06:41 AM
2014-01-19
06:41 AM
bastardo wrote: at the moment, the only way to use WPA2 is WPA-PSK (TKIP) + WPA2-PSK (AES) mode, because if you select WPA2-PSK (AES) it will set WPA2 (TKIP), and TKIP support 54mbps.
I am using .17 (well my modified one to be precise) and afraid it works fine @ 5ghz set 'WPA2-PSK (AES)', sitting next to it I get 300.
xxxxx@xxxxxxxxxxxx:~$ iwconfig
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 IEEE 802.11abgn ESSID:"xxxxxxx"
Mode:Managed Frequency:5.18 GHz Access Point: xx:xx:xx:xx:xx:xx
Bit Rate=300 Mb/s Tx-Power=15 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=69/70 Signal level=-41 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:12 Invalid misc:71 Missed beacon:0
04:00.0 Network controller: Intel Corporation Centrino Advanced-N 6230 [Rainbow Peak] (rev 34)
Subsystem: Intel Corporation Centrino Advanced-N 6230 AGN
Flags: bus master, fast devsel, latency 0, IRQ 48
Memory at c2600000 (64-bit, non-prefetchable) [size=8K]
Capabilities:
Kernel driver in use: iwlwifi
Message 30 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-02-13
05:56 PM
2014-02-13
05:56 PM
This is a but introduced in the last official firmware. I was able to workaround by doing the following.
1: set wireless to tkip + aes.
2: set wireless channels to Any channel in middle of spectrum.
Apply. Reboot.
3: set wireless to aes. Increase speed selectors to 300mbit.
Apply.
Fixed.
Apply. Reboot.
Apply.
Fixed.
Message 31 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-02-18
03:03 AM
2014-02-18
03:03 AM
Just had a peruse of the source from .12 and .17 and Netgear have fiddled with quite a few things in the 5Ghz pages (/www/WLG_5g_*) to do with the region/frequency band settings, I guess they flanged the logic up somewhere, which doesn't surprise me judging by their code. If I get even more bored at work I may try and unpick it.
Message 32 of 32
- « Previous
- 1
- 2
- Next »
Announcements
