Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DGND3700..Won't reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-03-01
10:51 PM
2014-03-01
10:51 PM
My Netgear DGND3700 has all of a sudden stopped letting me connect to it, wireless or wired. I have tried using the reset method numerous times but it doesn't work. It won't reset back to factory.
The power comes on and the DSL light just flashes green continuously. I have tried plugging it via ethernet to my computer but it won't recognise it.
The only lights that come on for the rear of it are LAN 3 and 4,which are green and the Ethernet Wan port which is orange.
Thanks for your help.
Message 1 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-03-02
09:32 AM
2014-03-02
09:32 AM
Re: DGND3700..Won't reset
Remove all cables and leave off of 10-20min
Only apply power and reset the unit
Then plug only once PC to the router and try again
If continue to fail and unit is under warranty then I would contact support for RMA exchange
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-03-02
05:35 PM
2014-03-02
05:35 PM
Thanks, I tried the reset you suggested but still no luck. When i plug my phone line in the only thing that changes is the dsl light stops blinking.
Looks like I'll be buying a new one.
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-03-03
05:21 AM
2014-03-03
05:21 AM
badger, you can have a go at doing this, parts will cost almost nothing, and you don't need to solder if you are careful.
http://www.richud.com/wiki/DGND3700_V1_CFE_Boot_Loader_TFTP_De-Brick
Message 4 of 4
Announcements
