Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DGND3700 as AP
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-17
07:54 AM
2014-01-17
07:54 AM
DGND3700 as AP
Hi,
Not using ADSL from long time now, I have this router on a shelf. I would like to give it a "new" life by using it for extending my WIFI network. I have a wifi cable router downstairs and upstairs the wifi signal it's too low to be detected. I have a 200MB internet connection so Gigabit it's a must. I tried to configure my DGND3700 following a guide from netgear, it "works" but I have to select manually a static IP for each device (iPhone, computer...) to let it connect. They don't get automatically an IP address. What can I do for solve this? Shame that the router doesn't have an AP mode 😞
Thanks
Thanks
Message 1 of 10
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-17
08:29 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-18
01:04 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-18
04:52 AM
2014-01-18
04:52 AM
Re: DGND3700 as AP
You've turned off DHCP on the DGND3700?
Does it make a difference if you fix its IP address?
There was a long and detailed account of using an old router as an extender. It involved various steps that went beyond what I would have expected.
Can't remember the links but I did find these
Different models and circumstances but maybe some clues: Using an FVM318 Wireless Router as a Wireless Access Point
and
Using WPN824, WGR614, or WGT624 Routers as an Access Point
The point that struck me was
Also this one:
How do I set up a wireless router as an access point on a network that has another router serving as...
and
Configuring a router (WNDR3800) as a wireless repeater
Maybe someone can remember the other stuff.
and
DHCP configuration may not work reliably because the wireless router/access point may not correctly relay DHCP information from the router. Workaround: Use static IPs on the wireless PCs.
Also this one:
and
Message 4 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-18
06:56 AM
2014-01-18
06:56 AM
Re: DGND3700 as AP
There isn't really specifically said on method of network setup
Two devices connected with ethernet cables or achieving two devices wireless to extend.
In either situation 2nd unit's DHCP should be disable if there is existing DHCP such as main router that is been used
Message 5 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-18
08:24 AM
2014-01-18
08:24 AM
Re: DGND3700 as AP
As I said on my first post, DHCP was disabled.
Message 6 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-18
08:25 AM
2014-01-18
08:25 AM
Re: DGND3700 as AP
michaelkenward,
The AP had a fixed IP address outside the DHCP range.
As I said if I assign manually an IP to a device it works but that's not what I want.
Message 7 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-18
08:55 AM
2014-01-18
08:55 AM
Re: DGND3700 as AP
Regardless of meteor method (AP or repeating ) it should pass the dhcp from the main router
There is thread on DGNxxx model used as ap or repeat that so not pass dhcp
Message 8 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-18
02:54 PM
2014-01-18
02:54 PM
Re: DGND3700 as AP
jmizoguchi wrote: Regardless of meteor method (AP or repeating ) it should pass the dhcp from the main router
How can this be solved?
Message 9 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-18
07:00 PM
2014-01-18
07:00 PM
Re: DGND3700 as AP
Best bet is to contact support . This some firmware related issues
Message 10 of 10
Announcements
