Orbi WiFi 7 RBE973
Reply
DGND3700v2 - Limiting YouTube using QOS
mulkman
Hi,
I need to limit the amount of bandwidth/priority my sister gets on her iPad for youtube
Can this be done with the QoS functionality on this router?
I have tried to map all the mac addresses within the home to the QOS interface and then set priorities based on that.
Still doesn't seem to be working ?
Message 1 of 3
Retired_Member
Not applicable
Re: DGND3700v2 - Limiting YouTube using QOS
Short answer No.
You could setup a priority based on mac addresses, but that only works if two or more are using network at same time. If your goal is to limit usage or set a limit then it won't help.
Message 2 of 3
jmizoguchi
Virtuoso
You can not just choke band with for single domain.
You can only control a "device" with QoS that you tried tried as one. Consumer unit also has less setting for controlling the bandwidth.
Prosafe/Prosecure will allow moire depth of controlling the bandwidth with bandwidth profile
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 6067 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
