Orbi WiFi 7 RBE973
Reply
Devices not connecting to Home Network
LenJam
Follower
Netgear Router DGN2200v3
Out of the blue my Samsung S3 lost wi fi connection showing 'Authentication error occurred', initially I thought it was the phone but I now find that my Marantz Receiver connection(Internet Radio etc) and my laptop have all dropped connections to the Internet.I have rebooted all 3 and entered the correct password etc....no joy. HOWEVER  my PC and wifes's IPad are connected to the router/internet as normal with no problems.
Is it the settings on my router that have changed and is blocking those 3 devices? do I need to restart my router  etc
Any help appreciated
Thanks
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Devices not connecting to Home Network
Hello Lenjam
To make sure that these devices are not being blocked you want to log into the router go to wireless settings under the advances area then check to see if anything is added under wireless card acess list. Also on the 3 devices that cant connect go into the wireless settings on those devices and tell them to forget the network then try reconnecting to the wireless. If that all doest work you can always try to do a factory reset on the router but you will have to redo any of the settings you have setup.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3057 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
