- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How do you set up Nighthawk D7000 as a wireless repeater/range extender?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cheers in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How do you set up Nighthawk D7000 as a wireless repeater/range extender?
There's also Powerline but I personally think they are more trouble than they are worth; others do swear by them. If a wired solution is not an option, then get a real range extender as a last resort.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't like swearing in public, but I am a powerline believer.
The technology has come a long way in recent years. (It had to, to stay alive.) It now even offers GB LAN.
The advantage is that it gets rid of wifi, always a difficult technology, best used for kit that you move around. If you have something that doesn't move, powerline is a viable option.
You could even use powerline to turn the D7000 into an access point.
By the way, I would not rule out the simplest option. The D7000 has an Internet socket on the back. Connect that to the modem from your ISP and you have an access point.
Also check to see if your flavour of NBN will let you use the D7000 rather than the modem they supplied:
What is an NBN network and is my NETGEAR DSL modem router compatible?
