Orbi WiFi 7 RBE973
Reply
Modem is working but can’t connect to it. Passwords are wrong
Jasim
Model: D3600|N600 WiFi Modem Router - 802.11n Dual Band Gigabit
Message 1 of 4
Accepted Solutions
Jasim
Re: Modem is working but can’t connect to it. Passwords are wrong
I have had this for almost a year. Nothing happened and it’s the WiFi password for the Neatgear35 and the guests also. All 4of them
Message 3 of 4
All Replies
Guru
Which password? The wifi password? the passwords to log into the administration?
Some details help.
Are you using the D3600?
Did something happen? Is this a new device?
you can go to netgear.com/support  and type in the model number. It'll take you to the manual, firmware, and install guides.
Message 2 of 4
Jasim
Message 3 of 4
Guru
You can hardwire into the device and log into it. From there you can change the wireless and password.
Message 4 of 4
Discussion stats
  • 3 replies
  • 1268 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
