Orbi WiFi 7 RBE973
Reply
Need help reconfiguring my router/modem N600
TrishaRam
Follower
My modem was factory reset by mistake and I am unsure how to get it reconfigured.
Message 1 of 3
antinode
Guru
Re: Need help reconfiguring my router/modem N600
> [...] my router/modem N600
   Not a model number.  Look for "Model" on the product label.
   With that datum in hand, you might try this radical concept:
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual (at least).  Read.
> [...] I am unsure how to get it reconfigured.
   Same here.  I don't even know what it is.  Or who/what your ISP is.
Or your type of service.  Or anything useful, really.
Message 2 of 3
Visit the support pages:
Support | NETGEAR
and feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
A good place to start is the Quick Start Guide for whatever it is that you own. It is the thing they stuff in the box the thing arrived in. With luck you  need to go to the hassle of reading the whole manual.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 663 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
