- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear D6400
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear D6400
Can Netgear please put new thread Netgear D6400 for new VDSL router
http://support.netgear.com/product/D6400
I need to know if this router support G.998.4 (g.inp) and vectoring?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
I don't have it by me in the office at the moment. It is the one I use in the house
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
From other forums it looks like the D6400 used the BCM63168 chipset so in theory should support G.998.4 (g.inp) and vectoring. However, it may not have been enabled in the current firmware. The question has been submitted to Netgear support but no response as of yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
Yes, the D6400 supports G.998.4 for DSL and G.INP and Vectoring for VDSL. Since the D6400 is VDSL capable, this is also a backward compatible with ADSL, ADSL2+ and DSL.
So we can all treats easy that our purchase is (a little) future proof.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
Unfortunately, the beta forum is closed so I can't see if that ever came up in discussion.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
It may be nice for someone from Netgear to step in and provide a definitive answer top this question as otherwise this new product may sink in many markets that need this support! Ideally with some evidence that G.IMP is supported.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
Maybe he will reply.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
For Vectoring and G.INP, it will be supproted by next FW release. It is around in early June.
Best Regards
Allen Lai
NGR PEM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
Hardware Version D6400
Firmware Version V1.0.0.22_1.0.22
GUI Language Version V1.0.0.22_3.1.2.5
The D6400 stats was also reported with dslstats v5.4:
Stats recorded 01 May 2015 13:28:40
DSLAM/MSAN type: BDCM:0xa44f / v0xa44f
Modem/router firmware: AnnexA version - A2pv6F039j.d25d
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime:
Resyncs: 0 (since 01 May 2015 11:13:38)
Downstream Upstream
Line attenuation (dB): 11.1 0.0
Signal attenuation (dB): Not available on VDSL2
Connection speed (kbps): 79999 20000
SNR margin (dB): 11.7 15.7
Power (dBm): 12.4 1.0
Interleave depth: 16 8
INP: 46.00 47.00
G.INP: Enabled
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
"The old Netgear Windows telnetEnable.exe sends probe packets to the router's TCP port 23. Thus, it is not compatible with firmware and routers Netgear introduced after early 2014, which require UDP port 23."
http://wiki.openwrt.org/toh/netgear/telnet.console
However, a developer has modified the unlock tool in order for this to work. The exe file can be found on git hub.
How to Unlock Telnet.
1) Download the unlock tool from here https://github.com/LuKePicci/NetgearTelnetEnable/blob/master/binaries/windows/telnetenable.exe
2) Once downloaded run the following command telnetenable.exe {IP ADDRESS of D6400} {MAC ADDRESS of Router LAN Port} {user id} {password}
What you type should look similar to this
telnetenable.exe 192.168.1.1 000FB5A2BE26 admin helloworld
If you have done this correctly, you should now be able to use telnet.
3) On dslstats, select any netgear router - i think i selected the last one in the list.
4) Leave user ID and Password blank on DSLstats.
5) No other settings required.
Hope this helps.
Remember, each time you reboot the router, you will have to unlock telnet again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
Cheers.
Rick.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
http://www.downloads.netgear.com/files/GDC/D6400/D6400_UM_14May2015.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
how did you get those stats?
I am on plusnet fibre but router stats say on adsl
Show Statistics |
System Up Time 4 days 21:35:37 | |||||||||||||||||||||||||||||||||||||||||||||||||
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
Warning to all users who land on this thread.
The latest firmware for this modem causes problems on BT and TalkTalk in the UK.
Two of us see the same thing. It drops the connection from time to time.
D6400 keeps dropping internet connection - NETGEAR Communities
D6400 Firmware Confusion - NETGEAR Communities
Here's what I said over there:
The symptoms I see are that the PC starts throwing Internet connection errors while the modem still shows that it is connected. Eventually the Internet light changes colour.If I go to the Connection Status, the windows is frozen. The Connection time, in particular, is stuck. If I then try to Disconnect/Connect, nothing happens. Earlier modems would show that the thing was trying to reestablish a connection. In the case of the D6400 and the new firmware, the only way to restore the Internet services is to reboot the modem.
The old firmware had none of these problems. I would use it only if it adds features that I needed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6400
router d6400
Firmware Version
V1.0.0.34_1.3.34
this is the firmware on my router and have been running this for a few weeks now with no diconnect problems.
downloaded it and had a disconnect but did a factory reset and worked fine after that
isp is plusnet and connection time is 28 days
