Orbi WiFi 7 RBE973
Reply
Netgear D7000v2 requires constant reboot v1.0.0.51_1.0.1
chrisbaughan
Follower
I have to reboot daily and posted recently but replies are not helping. The latest says "log in and open MY PROFILE. Where is MY PROFILE ?  Other answers are way beyond my intellect. Can someone please give an answer in simple terms. I paid £150 for this kit and have a laptop and Ipad on the system - or are our iphones on too ?
PS  I had a message "IP address conflict"  Any idea what this means please.
Message 1 of 3
Guru
Re: Netgear D7000v2 requires constant reboot v1.0.0.51_1.0.1
You shouldn't need daily resets.  Here's what I'd do and the order I'd do it in.
1. Reset the system back to factory.
2. Update the firmware to version 1.0.0.53. do it over a hardwired connection for best results.
3. reset the device again. Anytime you do a firmware upgrade, its best to restart the device.
4. do you have something connected before the D7000v2 or is it connected via dsl? (ip conflict question) or is there another routing device on your network?
here's the support page for your d7000v2. it has manuals, firmware, etc.
https://www.netgear.com/support/product/D7000v2.aspx
Message 2 of 3
Guru
btw here's the appropriate forum for dsl combo devices.
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 803 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
