- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear d7000 internet problems
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear d7000 internet problems
Have you disabled uPnP ? I know a lot of people advise doing this but it caused me a number of problems, including the router locking out Wifi connections on a regular basis. Only a reboot would fix it as well
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Johntsam
Here is a article on Upnp but you should try to do that also make sure you are on the latest firmware.
http://kb.netgear.com/app/answers/detail/a_id/22686
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Again I'm gonna have to reset it to get it back. I really hope netgear fixes this or I'm never going to buy anything from them again
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Johntsam
If this keeps happening I would suggest contacting Netgear support if the modem is still under warranty they can troubleshoot with you more and if the unit is defective they can do a RMA if needed.
http://support.netgear.com/general/contact/default.aspx
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Don't make the same mistake i did
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Johntsam
have you tried to tell the samsung devices to forget the network that try to connect again.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Johntsam
Did lowering the mbps correct the issue? or was it just a temporary fix let us know.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Check back if it disconnects again
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello johntsam
You could try going back to the old firmware to see if that helps or try to factory reset and reload the firmware.
DarrenM
