Orbi WiFi 7 RBE973
Reply
Nighthawk D7000 no lan lights
Ford501
Follower
I just got a d7000 and its working fine but there is no lan port lights on the d7000 when computer is connected is there a setting you have to change to make it work or what
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 2
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Nighthawk D7000 no lan lights
Hello Ford501
Check in Advanced-Advanced Setup-LED control Settings if you have that you can turn it off or on if not something may be wrong with the LEDs
DarrenM
Message 2 of 2
All Replies
DarrenM
Hello Ford501
DarrenM
Message 2 of 2
Discussion stats
  • 1 reply
  • 3923 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
