Orbi WiFi 7 RBE973
Reply
Nighthawk D7000v2 router
gaj07
Follower
Hi
My wifi cable into the house only has a Ethernet end and not a DSL end to fit into the router's port.  Can I connect another way?
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 3
Guru
Re: Nighthawk D7000v2 router
@gaj07 wrote:
Hi
Your phone/dsl cable comes into the house with an RJ45 connector and not a RJ11 connector?  Some RJ11 ends can look like a  rj45 ethernet end but are still the standard rj11 end. Take a closer look at it.
do you have dsl who is your provider?
How was it hooked up prior?
Message 2 of 3
antinode
Guru
> My wifi cable into the house [...]
   Which came from where, exactly?  (Note that "wifi cable" is not an
actual thing.)
> [...] only has a Ethernet end and not a DSL end to fit into the
   There are two hardware versions of the D7000. The D7000[v1] has a
"red Internet port".  The (newer/cheaper) D7000v2 has a shared "LAN 4 /
Ethernet WAN" port.
   Visit http://netgear.com/support , put in each model number, and
look for Documentation.  Get the User Manual.  Read.
   Note that the D7000v2 User Manual is lousy with errors, especially in
parts relevant to this.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 738 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
