Orbi WiFi 7 RBE973
Reply
Not able to connect more then 15 devices with Netgear D6000 - AC 750
Naval
Follower
Hi ,
We are using Netgear D6000 - AC 750 Router which was recently purchaged.
While using it,we found that we could not establish more then 15 connections at a time.
We get following error --
On laptops : shows error “try moving closer to your wireless router, alternatively run wireless diagnostics to trouble shoot”
On Mobile Devices : It just do not connect to netgear and switch to other network.
Model: D6000|AC750 WiFi Modem Router - 802.11ac Dual Band Gigabit
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Not able to connect more then 15 devices with Netgear D6000 - AC 750
Hello Naval
Make sure you are using the latest firmware on the modem. Also you may want and try to switch wireless channels in the wireless settings.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2919 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
