- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Port Forwarding
- Mark as New
- Bookmark
- Subscribe
- Permalink
Port Forwarding
Hello everybody.
I'm new in this community, so if the topic is in wrong section,I ask the moderators to move it in the most appropriate section.
I recently buy a new modem-router (Netgear DGND 3700V2); in my LAN I set up a small server (It's an old PC) with Ubuntu Server x32. All works great, but I've problem to forward some ports, in particular 1194 (OpenVPN) and 443 (HTTPS) on my server for VPN communications. It's strange because the other ports (for example 32400 for Plex, 22 for SSH etc..) work correctly.
I don't understand if it's router or server problem. Can someone help me? Thanks for replies.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port Forwarding
Hello Ghila96
Does it give you a error when you try to open those ports or does it allow you to add them to the router they just not working?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port Forwarding
Thank you for answer, and sorry for the later.
No, the router allow me to add this rule to the Firewall and open the port; but when I try to test the port (with "Port Forward Network Utilities" software or other Internet sites), the port result closed.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port Forwarding
Ghila96
make sure your on the latest firmware also you might want to try a factory rest and reset up the port forwarding.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port Forwarding
Sorry for later.
My actual firmware version is "V1.1.00.24_1.00.24"; the router tell me that this is the latest version available.
The reset is the only way? Because only that ports don't work properly...
