- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to connect to Cisco Modem (Charter)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just switched from AT&T DSL service to Charter Cable Internet. I am unable to get my D7000 to connect with the Cisco modem that Charter provided. I have reset the D7000 multiple times. Each time I go to routerlogin.net and from there I allow the system to automatically detect the internet, but the error message I am receiving tells me to 1) rebooot the modem and 2) Check ethernet cable. Tried those but still no luck.
Anyone know what I am doing wrong or can you offer insight? Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to connect to Cisco Modem (Charter)
Are you using the RED port, for cable Internet? Is the Cisco a modem only, or a router modem combo? If it's latter, can you put into bridge mode (modem only)?
EDIT: for cable modem set up: router manual - Page 31.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for replying. Yes, I am using the RED port. The Cisco is a modem only. I followed the directions that you included and still ending up with the same results. I appreciate your assistance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is your modem registerd with your ISP? That can certainly stop you from connecting.. Also, do you have a link lights between the port on the router and Cisco modem? If you don't try a new Ethernet cable / make sure both ends are propoerly seated (you shoudl hear a click on each port)..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem was provided by Charter and is registered, and I have tried a few Ethernet cables. I will just end up getting a wireless router through Charter, which I didn't want to do. I specifically purchased the D7000 back in January with the intent of switching from DSL to cable when Charter finally became available. Oh well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can always try to reset the D7000 to facotry default and see if that changes anything..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe the WAN port is bad. If you can return it, then do that..
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was wondering if that might be the case, but when the cable is plugged into the RED port, the light is illuminated orange. Is there a way to test the RED port to see if it is working?
I did notice that when I log into routerlogin.net -> advanced -> advanced home -> Internet Port has a red X associated with it. Not sure if this means anything or not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That means the internet os down. When you conect to the router what state is the WAN port in - up? down? speed? You shoud double-check with your ISP and ensure you new modem is registered. Have you tried directly connecting a laptop to the modem, to see if you could get to the interent?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure what you are asking when you want to know if the WAN port is up or down, speed. Where do I find that info?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello rcarnemolla
you can try to go to Advanced- Setup- Wan Setup and then for Wan preference you can select Must use Ethernet WAN see if that works.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi DarrenM,
I tried that already and still unable to connect. Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
rcarnemolla
If you have tried factory reset and its still not picking anything up on the WAN port you may want to contact Netgear support if the modem is under warranty so they can test and see if its a hardware issue and replace it if needed.
http://www.netgear.com/support/contact.aspx
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
rcarnemolla
Thought of another thing to try you may want and do mac spoofing here is a article on how to do this.
http://kb.netgear.com/app/answers/detail/a_id/1086
DarrenM
