- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
VPN
- Mark as New
- Bookmark
- Subscribe
- Permalink
VPN
Hi Guys
Having a real issue getting my nighthawk VPN to use my public static IP address when I connect to the VPN, has anyone managed to get this work properly? annoying how I cant do much confiuration for the VPN server on the nighthawk as well. I have set the option in tunnelblick to push all traffic through the VPN as well.
I am using Tunnelblick as suggested by Netgear and using MacOS sierra, ifocnifg output below
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
inet 127.0.0.1 netmask 0xff000000
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 3c:15:c2:df:85:3a
inet6 fe80::ba:471d:2dc3:ae48%en0 prefixlen 64 secured scopeid 0x4
inet 192.168.43.104 netmask 0xffffff00 broadcast 192.168.43.255
media: autoselect
status: active
en1: flags=963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX> mtu 1500
options=60<TSO4,TSO6>
ether 72:00:04:49:8e:20
media: autoselect <full-duplex>
status: inactive
en2: flags=963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX> mtu 1500
ether 72:00:04:49:8e:21
status: inactive
p2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304
ether 0e:15:c2:df:85:3a
media: autoselect
status: inactive
awdl0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1484
ether 66:4e:99:7c:0f:af
inet6 fe80::644e:99ff:fe7c:faf%awdl0 prefixlen 64 scopeid 0x8
media: autoselect
status: active
bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=63<RXCSUM,TXCSUM,TSO4,TSO6>
Configuration:
id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
ipfilter disabled flags 0x2
member: en1 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 5 priority 0 path cost 0
member: en2 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 6 priority 0 path cost 0
media: <unknown type>
status: inactive
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::937d:5d62:5814:4e2f%utun0 prefixlen 64 scopeid 0xa
tap0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether de:88:7a:4b:9a:ef
inet 192.168.89.8 netmask 0xffffff00 broadcast 192.168.89.255
media: autoselect
status: active
open (pid 639)
Cheers, Nikolai
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN
Welcome to the community, @nikolaistapleto
What's the exact model number of your NETGEAR device?
Did you try to factory reset the NETGEAR and then reconfigure it from scratch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN
Hi
It is a Nighthawk D7000, I havent done a hard reset of the device. Can you guys conflirm that the Nighthawk D7000 is able to serve a VPN and can change the device I am connecting to my static public IP that I have with my ISP?
Cheers, Nikolai
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN
Hello nikolaistapleto
You can use VPN on nighthawk as a client but not as a server.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VPN
Hi Darren
That doesnt make sense at all, my macbook is the vpn client and the nighthawk is the vpn server, how else can the connection work otherwise?
I can connect to the VPN service running on the Nighthawk D7000 fine, it just doesnt change my IP address to my static IP I have assigned by my ISP. How do I get it to to that?
