- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
powerline adapter will connect to the internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I cannot get the powerline adapters to work with my modem/router, amber light comes straight on each time i connect. have tested the lan/wan and all good, wired computer working as does all wifi.
The powerline adapters are connecting to a foxtel box and cannot receive the inetrnet or IP address.
I am not great with computers, but the wiring and connections are spot on.
any help appreciated - going crazy.
thanks
Damien
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: powerline adapter will connect to the internet
More details??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: powerline adapter will not connect to the internet
Hi
- Mark as New
- Bookmark
- Subscribe
- Permalink
"LAN port indicator light is amber"
this is normal for a 10 100 connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Instructions state that a solid white light verifies successfully connection.
my computer is connected no dramas same cables, and loop test also successful using same cables-shows white light.
hence i am having issues connecting to the powerline adapters
- Mark as New
- Bookmark
- Subscribe
- Permalink
I guess I misunderstood which LED was amber ..I meant router lan port
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any suggestions searay on why the nighthawk is not recognising the powerline connection via ethernet cable?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi klutz99,
Correct me if my understanding is wrong.
Router-->LAN port--> 1st powerline adapter
2nd powerline adapter --> TV box
1. How far is the 2nd powerline from the 1st powerline?
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi James
Your understanding is correct.
The other powerline is two rooms away, approx 10 meters apart.
The adapters previously worked with no drama with my old modem?
I really do not understand what the issue is.
thanks
Damien
- Mark as New
- Bookmark
- Subscribe
- Permalink
When plugging adapter into lan port on router does that port led light up? Is the r7000 in router mode?
This statement is confusing at best "The adapters previously worked with no drama with my old modem" a modem is not a router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
The model is a D7000, but funnily enough this was not an option to select above, evrytime I typed D7000 the model area above selected "R7000"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's why the subject should start with router model then a brief description of problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Lan port lights up, but it lights up Amber which means no connection.
I am also aware that a router is not a modem but the Model selection option above will not allow the D7000?
Sorry for your confusion but I reckon the lights on the "R" and "D" versions work in exactly the same way indicating that there is no connection to what ever device that they are trying to connect with.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When plugging adapter into ROUTER lan port on router does that ROUTER port led light up? If it does light up amber on router IT MEANS a connection of 10 100 is established.
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI
I accept that, but the device is not working, the "Genie" does not list the devices mac or the sat tv IP addresses and the instructions state that a "White led indicates a successful connection", I have amber "not successful".
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi klutz99,
Lets try to isolate first the problem by connecting the two adapters in just one room where the D7000 is located. Connect a computer to the 2nd adapter and check if it can get an IP or a connection. Check as well the lights on the adapter.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi James
I will attempt your suggestions on Thursday, unfortunately away from home at moment. The lights on the adapter are all showing as working: 3 green lights each.
regards
Damien
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Damien,
Provide us feedback once you have done doing the steps I have provided. Looking forward for your update.
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Damien,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
