Orbi WiFi 7 RBE973
Reply
D7000 Not connecting to Telstra FTTN NBN
philquad
i have a new D7000 but didnt realise nbn would be here so fast
i accept that the D7000 seems not a good choice for nbn & the supplied modem works ok but
can i use it as a router? we tried the setup but it failed
been all through the manual, it detects the nbn modem but doesnt finish up
i will try the firmware upgrade, i saw on wingepool a hacked firmware somewhere may be better?
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 4
Accepted Solutions
Xdaveox
Guide
Re: D7000 Not connecting to Telstra FTTN NBN
Philquad try connect router to nbn box and telstra router to nighthawk it can be done ive come across this in my searching forums
Message 4 of 4
All Replies
DarrenM
Sr. NETGEAR Moderator
Hello philquad
You may want to check out this article.
http://kb.netgear.com/app/answers/detail/a_id/30439?cid=wmt_netgear_organic
DarrenM
Message 2 of 4
philquad
so the bottom line is
the D7000 works with fttn on its own but then you need voip phones if you want a house phone
but, it doesnt seem to work if connected to a WORKING nbn modem
so, its pretty well a dud buy if you get nbn on, great for adsl, bad for nbn
Message 3 of 4
Xdaveox
Guide
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 11513 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
