Orbi WiFi 7 RBE973
Reply
D7800 Nighthawk X4S AC2600 WiFi Router VDSL/ADSL Modem router, corrupt firmware
frantic23
Hello People total noob at any networking type stuff so any help would be epic.
So modem is working sweet as usual, then latr in to arvo few days ago flashing white light, quick search apparently its corrupt firmware. Now I didnt even update to firmware, why is it all of a sudden corrupt. Ive gone onto netgears support to download the newest firmware, and that comes up with disc image corrupt. Is there any other options to fix the issue or should I hit it with a dropsaw
Message 1 of 4
antinode
Guru
Re: D7800 Nighthawk X4S AC2600 WiFi Router VDSL/ADSL Modem router, corrupt firmware
> then latr in to arvo few days ago [...]
   Eh?  Can you provide an English translation of that?
> [...] flashing white light, [...]
   _Which_ "light"?
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual.  Read.  Look for the
LED descriptions and "Troubleshoot".
> [...] Ive gone onto netgears support to download the newest firmware,
   Which was what, exactly?  And then you did what, exactly?
> [...] that comes up with disc image corrupt. [...]
   "comes up with"?  When you did what, exactly?
      https://community.netgear.com/t5/x/x/m-p/1721037#M124018
> [...] Is there any other options to fix the issue [...]
   Hard to say, based on your "description" of "the issue", but if the
Power indicator on the router is flashing, then you may be a candidate
for the TFTP recovery scheme.  See, for example:
      https://community.netgear.com/t5/x/x/m-p/1622096#M102004
Message 2 of 4
frantic23
The power light flashes white.
Downloaded the firmware which was a zip, extracted it and it comes up with disc image corrupt.
With TFTP the box was un ticked, when l ticked the box is that it anything else need be done.
On netgear support cant find anything to answer my problem
Message 3 of 4
antinode
Guru
   Ok.  Then I'd try the TFTP recovery scheme, as suggested before.
   Which "the firmware"?  The file has a name, yes?
   Still wondering.
   Did you read any of that?
   Huh?  "the box"?  I have no idea what any of that means.
   What more do you need?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 830 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
