Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DGN2000 Not Working With AT&T?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-11-02
09:58 AM
2009-11-02
09:58 AM
I have searched the message board and can not find an answer. I am using a Westell 6100 and it accesses the Internet correctly. When I try using my Netgear DGN2000 I do not get a DSL lock.
Are there any special modem/router settings to get a DGN2000 to work with AT&T DSL service?
Thanks in advance.
Joe
Thanks in advance.
Joe
Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-11-02
10:16 AM
2009-11-02
10:16 AM
Re: DGN2000 Not Working With AT&T?
call netgear support or call ATT support for correct DSL info to setup on your router
Message 2 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-11-02
10:44 AM
2009-11-02
10:44 AM
I'll try contacting Netgear.
AT&T will not discuss ANY modem that isn't supported by them. As of right now, that includes the 2wire, the old Motorola Netopia and the Westell 6100.
Installer states "That will not work with AT&T DSL service." That's even though I read all the time where people are using the DGN2000 with AT&T.
Once I get the results I will post back.
Thanks
Thanks
Message 3 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-11-02
01:18 PM
2009-11-02
01:18 PM
netgear may have vital DSL setup info you need to or may find in thread somewhere.. 🙂
Message 4 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-11-03
04:28 AM
2009-11-03
04:28 AM
You'll need to find out the VPI/VCI info that your pone company uses and determine the ADSL connection type (login, IPoA routing, etc. from AT&T. The auto-setup feature might also be able to help determine this information for you.
Message 5 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-01-07
02:20 PM
2010-01-07
02:20 PM
Did you ever get the Netgear working with AT&T?
Message 6 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-01-14
10:31 PM
2010-01-14
10:31 PM
did you get this working ? I'm trying to replace my older Netgear/Wirespeed Modem combo which works but the DGN2000 doesn't detect the DSL line.
Message 7 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-01-15
06:40 AM
2010-01-15
06:40 AM
Never got it working. Gave up. Didn't find anything that helped.:eek:
Message 8 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-01-15
07:10 AM
2010-01-15
07:10 AM
thanks ... did you just return it then saying it didn't work with a Major DSL Internet Service Provider ?
Message 9 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-01-15
08:26 AM
2010-01-15
08:26 AM
It is proven to be working with AT&T. As long as you have your PPPoE login & password (which is given by AT&T). And, you can also try these additional settings under 'ADSL Settings'.
Multiplexing Method: LLC-based
VPI: 0
VCI: 35
Take note that you should have a 'SOLID green' DSL light before you start configuring the device.
VPI: 0
VCI: 35
Message 10 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-01-15
03:33 PM
2010-01-15
03:33 PM
That is the problem. I don't have a solid green light. However, the Westell works fine. They both use pins 2 & 3 so it isn't the connection.
Message 11 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-23
11:47 AM
2013-09-23
11:47 AM
prodigy06 wrote: It is proven to be working with AT&T. As long as you have your PPPoE login & password (which is given by AT&T). And, you can also try these additional settings under 'ADSL Settings'.
VPI: 0
VCI: 35
I agree with the need to change the VPI setting from the default of "8" to "0". That helps to make the DGN2000 connect to the DSL line. 35 is already the default for VCI in the USA.
I must say, this DGN2000 router/modem seems to be a bit touchy, because once you reboot it or power it off, it usually takes quite a while to get the green DSL light again. In fact, this is why I quit using it about 5 years ago when I first bought it. But my ATT 2Wire modem just died and I needed another modem to get back online, so I figured that I would try the older DGN2000 router once again on my ATT DSL network.
The part that I disagree with above is the last line, that says "you should have a SOLID green DSL light before you start", because on my modem, I can't even get a sold green DSL light, until I change the VCI to 0. Mine won't even connect otherwise to the DSL signal.
The other major pitfall that people are likely to make is that with ATT, you need to enter your complete email address, not just the first part. Also, the password that you need to use to connect to the Internet is NOT the same as your ATT email password! There is another PIN code that you need to get from ATT, to enter into the password field of the Network Settings page. This PIN can also be retrieved by logging into your ATT account from another working Internet connection with your ATT email and email password. This really was a bit convoluted, and that's why I took the time to post a comment here after spending a whole day figuring it out.
Message 12 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-09-23
11:50 AM
2013-09-23
11:50 AM
VPI: 0
VCI: 35
VPI: 0
VCI: 35
Message 13 of 13
Announcements
