Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DGN2200 Bridge Mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-10
01:27 AM
2010-10-10
01:27 AM
DGN2200 Bridge Mode
I just bought my DGN200 Router, works very good. Can somebody please tell me how to set it up in bridge mode (RFC 1483 Bridged)?
Does this router support PPPoe passthrough?
Thanks in advance.
Thanks in advance.
Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-10
03:37 AM
2010-10-10
03:37 AM
Re: DGN2200 Bridge Mode
This setup works with DGN2000, never tried it with DGN2200. You can test it though:
1. Access the web-user interface of the modem by typing http://192.168.0.1 in the address field.
2. When prompted, enter “admin” for the username and “password” for the password (if you haven't changed yet the password for the interface).
3. Once logged in change the address URL in the address bar from:
http://192.168.0.1/setup.cgi?next_file=start.htm
to:
http://192.168.0.1/setup.cgi?next_file=mode.htm
4. This opens a hidden configuration page on router. Select 'Modem (Modem only)' and click Apply. This will convert the router into a simple ADSL mode. Router (Modem + Router) sets the device to modem-router mode.
5. After setting up the modem to Bridge mode, Basic Settings option is gone under Setup tab. You could still configure the ADSL settings though.
6. You can now connect the DGN2200 to your router or computer and setup for a PPPoE connection.
to:
Message 2 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-10
09:12 AM
2010-10-10
09:12 AM
Thanks for the reply, but when I do that, I get:
404 Not Found
The resource you have requested is not available.
404 Not Found
Message 3 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-10
09:29 AM
2010-10-10
09:29 AM
that means you will not able to mdem mode
not all model can setup as modem mode
Message 4 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-10
09:40 AM
2010-10-10
09:40 AM
So I could have bought a cheaper brand modem for half the price of this one that can do more?
Message 5 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-10
09:42 AM
2010-10-10
09:42 AM
personally just use ISP provided standard DSL modem in bridge mode and get regular wireless router would be more suitable when you change ISP , you can still use wirelesss router where built-in DSL modem limits only to ISP with DSL
Message 6 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-11
10:28 AM
2010-10-11
10:28 AM
In the manual it states the following:
Network protocol and
standards compatibility:
TCP/IP, RIP-1, RIP-2, DHCP, PPPoE or PPPoA, RFC 1483 Bridged or
Routed Ethernet, and RFC 1577 Classical IP over ATM
How do I select the protocols?
Message 7 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-11
12:19 PM
2010-10-11
12:19 PM
I would check into telnet and see if you can do something
Message 8 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-10-17
02:02 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-02
01:37 AM
2012-01-02
01:37 AM
If anyone is still looking for a solution to this, I succeeded in getting my DGN2200 into bridged mode. The device seems perfectly capable of it, but they didn't put an option in the web interface, which I find unacceptable. I'm bridging my ADSL connection to a linksys access point which has much more stable wireless-N and has the ability to run dd-wrt.
The procedure I used is as follows. Yours may differ if you have another way to access telnet.
1. First, enable telnet by whatever means works for you. I used modfs to enable the telnet service, but any technique should work.
1. Disable the wireless transmitter.
2. Disable both DHCP server and DHCP client (I did the latter by simply assigning a bogus static IP address to the WAN port).
3. telnet into the DGN2200 and clear the IP address from the atm0 interface:
$ ip address flush atm0
4. Add the atm0 interface to the default bridge device (the one that would normally bridge wireless and wired ports):
$ brctl addif br0 atm0
5. Make sure whatever other router you are using is connected via its WAN port to a port on the DGN2200
6. On your other router, make sure the MAC address matches what your ISP expects (unless you're using PPPoE, which I don't know anything about, so you're on your own there).
7. This caught me the first time: make sure you aren't also still using this same MAC address on the DGN2200. You can just reset it to default or whatever.
8. Release/renew the DHCP lease on your router until you get a public IP.
I'm posting with this setup right now, and it's working fine so far. HOWEVER, the one major downside is that you have to perform the "brctl addif br0 atm0" command every time your DGN2200 boots up. You could build a custom firmware or modify modfs if you're feeling really adventurous. I just use a script on my linux box that connects to the DGN2200 and runs the command automatically.
So, there you have it - it IS possible, it's just not nearly as easy as it should be.
Message 10 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-02
05:59 AM
2012-01-02
05:59 AM
go to support.netgear.com and search open source
if you are good at compiling , you can make your own firmware ..:)
Message 11 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-10-21
07:35 PM
2015-10-21
07:35 PM
The device does have a Bridge mode function, but the issue is that the LAN still retains it IP Address.
This conflicts with the Router WAN Port when using the device(DGN2200v4) as modem.
Any suggestion on how to rectify this problem?
Thank you.
Message 12 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-11-24
07:33 AM
2015-11-24
07:33 AM
It's 2015, the firmware version is V1.0.0.64_1.0.64
It is no "hidden" configuration page (any more?) - it is right there in the advanced configuration menu.
tab 'Advanced' -> left-side menu 'Advanced Setup' -> menu point 'Device Mode' -> Device Mode 'Modem (Modem only)'
Message 13 of 13
Announcements
