Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DGND3700 Wireless N 5ghz speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-18
02:42 AM
2012-01-18
02:42 AM
Hi,
I have updated to latest firmware and since updating i have noticed that my wireless n 5ghz laptops/desktops are all showing connected at 54mbps only, this used to me 300mbmps but even if i take a laptop to same room as router it shows 54mbps.
is anyone else experincing this issue?
dee
dee
Message 1 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-18
05:23 AM
2012-01-18
05:23 AM
Re: DGND3700 Wireless N 5ghz speed
HARD RESET the router after flashing firmware if erratic behavior starts
Message 2 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-18
05:58 AM
2012-01-18
05:58 AM
Mines been comparative to .12 speed if you mean modem firmware. If you updated your pc it may have been using now non compatible features (extreme G)
Check what the lights are on the front of the device and check the manual to see what they mean as you could just be in compatibility mode (have a g device on same ssid [maybe a printer?]). My brothers pc had a G card so as soon as he got on I was either dropped or lowered to his speeds
Check the lights first to give you ideas.
Message 3 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-18
11:27 AM
2012-01-18
11:27 AM
I also have this problem but only when I am using WPA/WPA 2..if I switch off the encryption it will be back to 300 transmit rate.
So I am keeping SSID Broadcasting to Off and Wireless Card Access List to On till they will release a firmware to correct this bug.
Message 4 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-18
11:42 AM
2012-01-18
11:42 AM
macinmac wrote: I also have this problem but only when I am using WPA/WPA 2..if I switch off the encryption it will be back to 300 transmit rate.
did you check any driver/app for for you wifi adapter you are using? goto chipset manufacture site for driver/app
sometimes it can fixes the issues
Message 5 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-18
01:17 PM
2012-01-18
01:17 PM
jmizoguchi wrote: did you check any driver/app for for you wifi adapter you are using? goto chipset manufacture site for driver/app
Well I'm using an iMac 8,1 and it supports 130 transmit rate...I don't have an adapter.So in my WI FI settings I have 130 transmit rate with WPA/WPA 2 off and 54 transmit rate with encryption on.
Message 6 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-18
02:58 PM
2012-01-18
02:58 PM
iMac 8,1 you mean latest iMac?
Message 7 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-19
01:09 AM
2012-01-19
01:09 AM
Hi,
it was fine before i updated software, it was picking up 300mbps before and after update only 54.
i do not think it is incompatobilty as all my devices are wireless n.
dee
dee
Message 8 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-19
04:46 AM
2012-01-19
04:46 AM
jmizoguchi wrote: iMac 8,1 you mean latest iMac?
It's an iMac late 2009.
Message 9 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-19
05:38 AM
2012-01-19
05:38 AM
deek19790 wrote: Hi,
dee
software meaning the iMac side or referring to firmware on DGND?
Message 10 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-30
05:26 AM
2012-01-30
05:26 AM
The light on the router stays blue. I this supposed to be green?
Message 11 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-30
05:30 AM
2012-01-30
05:30 AM
both band shows different LED color. as long as it is lid then should be okay
Message 12 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-30
08:03 AM
2012-01-30
08:03 AM
Hi.
I can only connect at 54Mbps on 2.4 or 5ghz.
I'm using latest firmware (18), latest wifi driver and wmm is on.
I'm a new user, havn't tried old firmwares.
I have a wifi usb dongle and i'm using it under win7 x64.
Its specs say: 54Mbps data transfer rate and up to 300Mbps @64dBm. Does it mean I have to do something to enable the 300Mbps or is it a FW problem?
Message 13 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-30
08:26 AM
2012-01-30
08:26 AM
Make sure you are using WPA2-AES security in order to get over 54Mbps.
Message 14 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-30
08:29 AM
2012-01-30
08:29 AM
Yes, I'm using WPA2-AES.
Should I try disabling security?
Message 15 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-30
08:36 AM
2012-01-30
08:36 AM
Always worth a try for troubleshooting. Make sure the USB has the latest drivers and the 3700 the latest firmware.
Message 16 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-30
10:31 AM
2012-01-30
10:31 AM
Disabling security brings a 72mbps connection.
Well, it looks like there are some problems.
It has perfect signal (as reported from realtek signal power 100%, connection quality 100%).
Why can't I reach max speed?
Message 17 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-30
02:42 PM
2012-01-30
02:42 PM
Well, I suspect the USB adapter. Might want to try a name brand.
Message 18 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-02-05
10:48 PM
2012-02-05
10:48 PM
Hi,
I can confirm that this model works up to 300MBs for 5Ghz when no password is set.
Once set to WPA2-PSK (AES) the wireless speed drops to 54MBs.
The problem is with the NetGear firmware not the Mac as I have a Mac Pro 2010 and I am experiencing the same issue.
Current firmware used - V1.0.0.17_1.0.17
NetGear please investigate a solution.
Regards
Dejoko
Regards
Dejoko
Message 19 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-02-05
10:53 PM
2012-02-05
10:53 PM
Forum is not support so please big report using my.netgear.com portal
Message 20 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-02-09
03:03 AM
2012-02-09
03:03 AM
I have the same problem, but you you chech, you are connected in TKIP, not AES, if I try to change from TKIP to AES, i can't connect
Message 21 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-02-15
08:45 AM
2012-02-15
08:45 AM
Hi,
Just an update for you guys, my second router died now, well it would not turn on again therefore netgear have replaced it.
it came with older firmware and i was connected at 300 on wireless n on both my macbook pro and also my pc wich is using NETGEAR WNA3100, after this i upgraded my firmware and the results are it won't connect above 54mbps now.
this proves to me its the firmware and not hardware as it was fine before i updated.
dee
dee
Message 22 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-02-19
09:34 AM
2012-02-19
09:34 AM
I too can confirm that with security set to WPA2-PSK(AES) that the max connection speed is 54Mbps on the 5GHz radio. And even though the DGND3700 is set for AES it is really doing TKIP. TKIP should allow for 150Mbps, but it seems to act as though it's throttled back to WEP 54Mbps. I have backed off from the .17NA firmware to .12NA and the 5GHz connection rate is no working the way I have it set with AES and 300Mbps.
Message 23 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-02-19
09:51 AM
2012-02-19
09:51 AM
I meant NOW working in the last sentence.
Message 24 of 32
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-02-22
08:54 AM
2012-02-22
08:54 AM
at the moment, the only way to use WPA2 is WPA-PSK (TKIP) + WPA2-PSK (AES) mode, because if you select WPA2-PSK (AES) it will set WPA2 (TKIP), and TKIP support 54mbps.
Message 25 of 32
Announcements
