Orbi WiFi 7 RBE973
Reply
DM200 modem with nighthawk R8000
flyingscotsman
Hi Folks
Just changed my modem router supplied from my Isp as it was crap to say the least. I have bought a DM200 and a Nighthawk R8000 which is working perfectly and getting good speeds. I have a 80/20Mb connection.
My question is: Should my DM200 be set to modem only when connected to my nighhawk router or is it ok to leave the Dm200 as a rmodem router. I am not having problems but just would like to know what the correct settings should be as I tried a leak test from GRC.com and my firewall failed the test,
Thanks in advance for any help offered or given.
FS
Message 1 of 4
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: DM200 modem with nighthawk R8000
Yes for best results set it to modem only when using another router.
DarrenM
Message 2 of 4
All Replies
DarrenM
DarrenM
Message 2 of 4
There is a manual for the DM200 somewhere at the end of this link:
>>> DM200 | Product | Support | NETGEAR <<<
See page 69.
Message 3 of 4
flyingscotsman
Hi
Thanks for the replies, I had the modem set as a modem/router , think this was the default settings, but as it was connected to an R8000 nighthawk, did wonder. It works perfectly well in default settings but I'll go change it now.
Thanks Again
Keith.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2003 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
