Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Dgnd3700 flaws
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-21
10:23 AM
2011-10-21
10:23 AM
Dgnd3700 flaws
Last week i bought your DGND3700.
The setup was easy and the router now is working.
ADSL is stable but..... there are the following flaws:
the giga switch is slow;
the Wi-fi is very low powered. 5 Ghz signal disappear at 3 meter (1 wall) from the router. 2,4 Ghz is barely sufficient for a 120 sq meter one floor flat.
the usb ports are very slow. So slow that a WD 500 MB usb disk (7200 rpm) is totally useless if mounted there.
Are the flaws anything that firmware can fix or N600 serie has design problems?
Mimmo
Mimmo
Message 1 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-21
11:05 AM
2011-10-21
11:05 AM
Re: Dgnd3700 flaws
Mimmo59 wrote: Last week i bought your DGND3700.
You seem to be addressing Netgear support. This is a user-to-user forum only, so do not expect any replies from Netgear here. If you wish, you can open a case at my.netgear.com and let them know your concerns there. You may also wish to choose the option of not registering your product, just to leave the option open for you to return it.
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-21
01:11 PM
2011-10-21
01:11 PM
Re: Dgnd3700 flaws
well 2 points about your comments 5GHz has a shorter range then 2.4ghz wi-fi as it loses the power quicker due to a shorter wavelength
have you tried setting the router to use just 5ghz or just 2.4 if not all of your devices are 5ghz compatible?
also setting the speed to N only or G only will help as the router will not have to broadcast all these different modes at once
in regards to the gig switch being slow how are you mesmerising this?
also the usb port will be slow it has not been designed as a dedicated nas drive a HDD on a router via usb will always be slow as the max transer speed will be limited to how its conected eg 300mb via wi-fi this is also burst transmission so average speed will slow down
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-23
04:42 PM
2011-10-23
04:42 PM
Re: Dgnd3700 flaws
I have tested the unit with my cat 6 installation and am getting transfer rates above 100MB/s so the design looks ok. What rates are you seeing?
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-10-25
05:30 AM
2011-10-25
05:30 AM
Re: Dgnd3700 flaws
...... Similarly concerned about wireless strength (not sure if later driver updates have any chance of meaningfully addressing this one)!
Message 5 of 5
Announcements
