Orbi WiFi 7 RBE973
Reply
Does Netgear D6000 AC750 support VLan for Fiber connections
lozt
Follower
Hi I have a customer that bought a Netgear D6000 AC750. Im trying to setup in New Zealand to a Fiber connection. Manual says it can do Fiber in manual. But I have tried to connect it and does not work.
I got these setting from vodafone nz for other router installs
If the modem router is UFB capable, then yes, it should be able to work. The ONT needs to be plugged into the WAN port, and VLAN tag set to 10.
Other than that, you'll need to set it to Using DHCP, and that will set an IP address automatically. The connection itself is port based authenticated, so you will not need any user details to connect to the internet.
Im just wondering if the Netgear D6000 Supports Vlan?
Any help would be great
Thank you in advance 🙂
Model: D6000|AC750 WiFi Modem Router - 802.11ac Dual Band Gigabit
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Does Netgear D6000 AC750 support VLan for Fiber connections
Hello Lozt
You may want to read this article about Fiber connections.
http://kb.netgear.com/30439/What-is-an-NBN-network-and-is-my-NETGEAR-DSL-modem-router-compatible?cid...
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5100 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
